Hello guys. Working with a 07 mega cab with battery draining issue. Replaced batteris couple months ago thinking it might help. Truck can sit a couple of days and will completely pull down batteries. There is a pretty good draw when slightly touching cables to battery. Arks pretty good. If you sit in truck with door closed and ignition off (with/without keys in switch) about every 2 minutes exactly to the sec you can hear a noise in dash behind instrument cluster. Sounds like a click a hour gauge would make except a touch louder (very noticeable sound). Only thing i could figure that is pulling it down. Any ideas on what the sound is or what is causing it? Also put new tipm because of headlight issue but didn't fix this paticular problem. Thanks
