Definatly pull the injectors. I am a diesel tech, and "I" thought I could pull the head off my truck without hurting the injectors. It was off, and no problems, then I hit one with the buffing wheel cleaning the head surface off, effectivly weakening the injector tip, I needed to replace it to ensure no failure.
Replace the head bolts, exhaust manifold bolts. If the truck is bombed, torque the head the way PDR, Haisly, Shieds would do it, not to book spec. If the truck is bombed, I would recommend having the head milled, to make sure it is flat on installation. Remember the fuel line that goes around the back of the head. Pull the hood, it works much better in the corner of the shop, out of the way. Don't take the alternator off, just the belt and the top mount.
Order parts from Cummins. When I did mine it was cheaper to get a standard head gasket kit+ a . 010 over head gasket, to compensate for the . 010 off the head to make it flat. To order a . 010 over head gasket kit was $300+ more then buying a standard kit and thicker head gasket seprate. Cummins even bought my standad gasket back for list price out of the gasket kit.
Is this what you were looking for? Oh yeah, don't kneel on the fenders, when you get all done you will be able to see the dimples in the shiney paint. Been there, done that
Or where you looking for remove bolts before lifting truck up? :-laf
Oh yeah, my mind is in the gutter most of the time, and your title to the post gave me a good giggle! :-laf
