Good Luck ,it may work. Tap very lightly.
Have had to remove head and beat injectors out from the back side before, so even the Cummins puller doesn't allways work.
The Cummins puller is a slide hammer on a cable, its o. k. but not the best.
I have also made a solid link puller from an old injection line nut and welded into a slide hammer. Snap-On also sells a nice puller, its a little long for some Industrial hood clearances, but is adaptable to a shorter slide hammer. The snap-on slide hammer kit also comes with different adapters and hooks for a variety of pulling situations.
A Johnson
