I have a 2001 HO diesel, six speed truck, with about 1,000 miles on it now.
The truck has a steady, substantial pull to the right. Remarkably, however, on a two lane highway, driving on the left side of the center line, it most often will go off to the left. On a low crown highway, like the freeway, the left side performance is typically that it will go to the right. Only rarely does it not display this pull.
My '99 Ram 2500 always wandered, a condition the dealer described as normal operation, and a condition I never accepted as normal operation. I used to do alignment work years ago, and was a dealership mechanic in automobile and truck dealerships, so I am not the typical customer, perhaps.
I had the alignment checked at a truck shop, and they determined it was correct. The truck does not pull when you brake, so I am not sure if it is a brake problem. My 1999 V10 truck had a quite a brake pull that came on suddenly, necessitating the use of some service shim scenario to solve it.
Are many of you seeing problems with pulling, rather than good tracking on the highway? The pull is even noticeable in town... .
