been chasing this for a while. the abs harness that runs along the outside of the frame on the left side, and to the sensor on the pumpkin. its held on at various spots with plastic clips, that do not clamp the harness tight. the problem was at one of these clips that was attached to the vertical rod that attaches to the sway bar. because it was not secure it moved up and down ,sawing through the black tape ,the plastic tubing, and finally the wires. the bare spots on the wires were grounding out intermittenting on the vertical rod. this was causing the abs to operate , and turning on the abs light. hope this can help someone else .
Oo. Oo.
