Pump Adjustment and Fuel Mileage
Is this a stock headgasket?
No Dash Lights
I remember a thread concerning pump tweaks and fuel mileage. Unfortunately I can not find it now. Does anyone else remeber the thread and would be able to give me an idea of what to search for. If I am not mistaken Pastor Bob wrote a long sermon in this thread. Any help would be appreciated.
Check out the stickies at the top of the forum. Basically your fuel mileage will depend on hard much you press the go pedal. Diesels use only as much fuel and horsepower that you request, unlike a gasser where if you mod for more HP you will use more fuel. You should find all you need in the stickies. If not just ask and you will recieve. :)
I'm not sure if there is anything specifically for pump adj, but the current issue of TDR has quite a bit of info regarding fuel mileage. You might also check out this current thread.
