Engine/Transmission (1994 - 1998) pump and dv question
Engine/Transmission (1994 - 1998) new turbo need help!!!
2nd Gen Non-Engine/Transmission Do I need a new thermostat?
ok guys here's the setup 291,000 miles on my 97 just installed some 370's and noticed a nice power increase but was running 40 lbs on stock holset so decided to upgrade to a dd jammer now i've got 4" exhaust and a afe intake kit should i bother with new dv's? how hard is the install? injectors took m3 45 minutes my fist time trying something like that so i guess i have mild mechanical ability. also does anyone know a pump shop in central califonia i want some timing done too since it's still set at stock. any info woud be great thanks fella's
deffintley get bigger delivery valves, there worth the money. i got the 191's, but there are also the laser cut delivery valves that flow more fuel..... you'll deffintely want to advance your timing 3-5. 5 degrees.
If you gonna go with DV's I recommend JR Adkins "Laser Cuts"..... they will definately add some fuel!! Oo. :-laf
That's where I'll be getting mine soon too! ;)
Adkins Diesel Performance 317-281-3130
what male in his 20's is ever happy with the power he has. If i could afford it i would have a 1000 hp truck with every gadget you can buy on it but i can't and smoke is a good thing trust me it stops people from tailgating:)
Smokng is a waste of fuel. You guys must have fat wallets with diesel at these prices. In my humble opinion, if I am not burning every CC of fuel I can, then I do not have things sorted out properly.
Dv's
The 191 dv's will make some more smoke and your new turbo spool up ALOT faster, i am happy with them. I would suggest you bump your timing up to 16* or higher this will help out power and mileage improvement too. Oo.
thanks
thanks nfox that is the info i was lookin for right there. Just finished hookin up turbo and spoolup is super fast i love it. Ofcourse have to change exhaust to stacks cause well ... ..... you guys know. So im runnin just the down pipe :--) hehe what a rush it sounds cool :cool:
