Basically the gist of my questions is does a higher hp p7100 exist(higher than 215)?
cerberusiam said:HTML:Basically the gist of my questions is does a higher hp p7100 exist(higher than 215)?
Yeah, it's called a Stupid Pump. Call PDR for more info.![]()
Jim Fulmer said:The trouble I had was running too much pump and not enough injector causing pre-mature cam wear. Cut cams are fine but to date have not made me anymore power. The cam in my stock pump is the same cam in my race pump, the only difference is the P&B's.
Jim
Jim Fulmer said:The cams in either the 180 or 215 pumps are the same, the cut cams allow more fill time. I have run both in my pumps, at first I thought the cut cams were a source of my pump troubles and kept quiet about it, but now I know it wasn't. The trouble I had was running too much pump and not enough injector causing pre-mature cam wear. Cut cams are fine but to date have not made me anymore power. The cam in my stock pump is the same cam in my race pump, the only difference is the P&B's.
Jim
RyanB said:Now I have heard this from a few people and also have heard the opposite about cut cams. What I have heard that in a truck pulling situation a cut cam for pulling will get you your fuel sooner and last longer. I know that my cut cam from piers looked nothing like my stocker did when it came back to me... I was amazed at how much was cut off! I also went with 13mm P&B's and its pushing quite a bit of fuel to say the least!
RyanB
JoshPeters said:That's quite a thought Jim! The only downside I can think of is premature wear to the pump inturnals due to the added pressure. Orifices maybe?
This sounds like a Grey area... . I like it!
JP
JAmos said:So cost wise, can any money be saved by buying a 215 cam, 13mm p&b's, delivery valves, and getting it all tuned together-versus buying a stoopid pump? Then with the extra fuel from this setup will it be too much fuel for 370's?
Doing these mods on a budget, which should come first, second, ect. ? The results will also be better having the pump tuned to each new mod right?
Jordan
