In case you guys haven't noticed, I have been doing an extensive look through of the archives and I have been comming up with questions from what I see.
Anyways... I came across a lot of posts about trucks not shutting off when the key turned off. Most people said it was because the pump was going.
This is scaring me because, if you remember, a few months ago for about a week I had to shut my truck off with that little lever on the fuel pump because it wouldn't shut off with the key. Sometimes if I let it sit for a while, it would die eventually.
Then one day it just up and stopped doing that. I haven't had a problem since. Also, a few weeks before it started not shutting off, I ran ATF through the system from the fuel filter because my injectors were a little clogged... I don't know if that had anything to do with it.
Should I be worried?
