Engine/Transmission (1994 - 1998) Pump ID? Who knows what model these PN's designate?
Looking at buying a used P7100 - can anyone translate the following for me? Do these PN's tell me whether this is a 913 or 887 pump? Thanks!
the sticker on the side of the pump is P=64 and one that is R48-50D the
end bosch tag on the end of the pump has these numbers RQV400-1400PA 1211K under it
The numbers you want to see are under the throttle assembly plate-three bolts hold it on. Remove that and you'll find a tag with three rows of numbers.
Top --PES6P120A120RS7346-1
Middle 0 402 736 854
Bottom 56500 13548
(copied directly from my old 160)
Now here's the one that counts.
Middle 0 402 736 913
It's that simple. I just pulled two 913's out of the junkyard. :cool:
