Pump/injector assembly questions
Tach help
Twins are born!!
Hey all,
I am confused about the injector thickness on the injectors. Can someone give me the rundown? Why would someone want a certain size? Can they be reused? I had the injectors in my truck tested and asked the shop if I needed new washers... they said just clean 'em up, they're okay to reuse?
Also, what is the torque on the delivery valves? I want to make sure they are all torqued correctly before I put the injector lines back in.
I ordered a FSM today. :)
They're cheap enough to use new ones when replacing injectors. They are supposed to be replaced with injector R&R.
