I just purchased a 180hp pump off a 96 auto that I’m going to install it on my 97 5spd, what I need to know is what CPL# should I use for the time of the pump. Should I use the CPL# of my 97 to find the correct lift settings to time the pump or use the CPL# of the 96 auto to set the timing and what would that number be.
I know there is a power difference between the two trucks, is it only because of the difference in the injectors or are there internal differences between the two pumps. Now if there is internal differences between the pumps how much power will be lost just by changing pumps, the injectors will stay the same.
Any help will be very appreciated.
97 2500 CC/LB 4X4, 5spd, 60 Gal. Aerotank, Geno's Combo Gage, Espar Heater,
[This message has been edited by Animal (edited 05-16-2001). ]
