As a new guy to the Ram, how much does the pump/injectors come ito play with high pyro readings? This was just treated to the Banks powerpack w/14 wastegated setup along with the ext, intercooler. < orig. had factory cooler > and the K&N. Just took it out for a test drive. @ idle I'm at 200 degrees. At 65 level road its running 625 deg. Bringing each shift up to max rpm in 4th its up to 900, shift into 5th and goes right down to 625 deg. I was told <tested> that the puter had a bad fault on the ATS air temp. Puter was ordered today. Also went with a recon turbo just to have a new one as I have spent a lot of $$ so far :<) The cap is still on the pump unit. I have no idea if it was ever adjusted. < bought used > The pyro is pre turbo. Any ideas guys ? Thanks, Mike
92 Std cab. LE. 98,000, 5-speed, 3. 54, 105 gal Aux tank in bed. Banks Power pack
