Engine/Transmission (1998.5 - 2002) Pump Keyway
Engine/Transmission (1998.5 - 2002) hot rod vp44
UPS just dropped off my replacement VP-44. Keyway on old pump is . 044, new one is . 036 . Is this the right pump for my truck {early 01'auto}? Called the vendor but they were allready closed. Any hints,tips on replacing pump?
The keyway is set to the pump on a bench test stand - you must use the key that came with the new pump. There is no 'right' key - it is whatever is needed to setup the pump.
You should have a SO pump. Compare the part numbers, however a SO ECM can use any pump. If you had a HO engine then you would need to have a HO pump only. So you are good to go - put it in.
