Hello, I have a '93 w250 ext cab which has been a great ,reliable truck. A couple of years ago it started to ,very slowly ,develop a fuel delivery problem. Eventualy I realised that the main fuel injection pump had a leak. I had the pump resealed and tested by a reputable shop here in Denver. After the pump was reinstaled(by the local dodge dealer ship) the air in the fuel problem is worse than before.
The symptoms are that I bleed the injectors then the truck will run for a while becoming more and more rough until it dies then wont start again untill I bleed the injectors again. Could any one suggest a systematic approach to tracking down where the air is geting into the system or what else I might try . thanks so much
