Is this a injector pump problem?
I had the injector pump and lift pump replaced by M&D diesel in Houston approx. 7K miles ago and also had them add a 60 hp chip. The engine ran great for 2 wks or so then started acting like you hit a governor or something about 1700 rpms, didn't die or anything just no power. If you let it go back to idle or push in the clutch quickly to get it down to 1000 rpms when you give it fuel it runs like he-- for maybe 5 miles or so then will do it again. Next day it may not do it at all , then start again in a week or so. When I talk to the shop that did the work, they say they can't find anything wrong. Could the chip be causing this, or the new pump? The shop will drive it around the block 2 or 3 times and bring it back with no problems, but will not take it out on the freeway and drive it steady for 30 minutes . Anyone have any ideas?
Thanks... ... ... ..... J. D. Poole
P. s. this is a 99 24v with 175k. pulling a trailer every day.
