OK; I understand that the pump has to be set up. Mine was setup on the bench when it was rebuilt. My question regards timing to the engine, much like distributor timing on a gas engine! I lined the pump up with the mark on the timing gear housing, but is that enough? What about performance timing? My Cummins puts out some smoke at idle. Can tining correct that?
http://coffeewithJesus. homestead.com/web1.html 89 1-ton, K&N, cleaned up exhaust, Dynomax straight-thru, rebuilt pump, intercooler, louvered fenders, 93 aftermarket smoothe grille; 78 35'Avion. Jesus saves!
