Engine/Transmission (1994 - 1998) pump timing - P7100 pump
2nd Gen Non-Engine/Transmission DSS availability in the US?
Engine/Transmission (1994 - 1998) Delivery Valves - RFI
Dan_69GTX
How to adjust the pump timing on the P7100 pump.
First let me say that VERY LITTLE of this information originates from me. It has all been gleaned from various posts and other web sites. A good chunk is from our faithful helper/friend Joseph Donnelly.
Is this the ONLY way to adjust it - NO! But it seems to be the most common.
First you are going to need tools! Besides your normal hand tools you will need the following special tools for the P7100 pump. You can get these from Snap-on or from Miller. Each tool set is a little different, but it will do the same thing. Get the one that seems best for you - ex: If you already have a barring tool, you will get another one if you buy the Miller tool set.
Snap-on set is part number SP500.
http://buy1.snapon.com/catalog/pro_...&group_ID=2964&store=snapon-store&dir=catalog
Miller set is SPX MILLER #6860.
http://www.spxmiller.com/
Various parts you may/will need:
Delivery Valve Washer
Mopar number 4778483 or 4874514
Bosch - 2 410 101 014
delivery valve o-ring
Bosch number 2 410 210 033
Pump gear lock washer
Mopar number 4761314
Cummins - 3920922
timing pin (TDC pin)
Cummins 3903924
timing pin o-ring
Cummins 3913994
What are the pros / cons of adjusting the timing?
http://www.piersdiesel.com/Faq.htm
There is a TSB on how to adjust injection pump timing - this I found at:
http://dodgeram.info/tsb/1994/18-10-94a.htm
There are 2 places for charts on the pump timing. You will notice that there is a slight discrepancy on the number for the amount of lift. Don't worry about it - you will not be that accurate anyhow.
http://www.dodgeram.org/tech/dsl/FAQ/timing.htm
http://www.piersdiesel.com/TechPTiming.htm
A problem that will may run into is "My TDC pin is broken off. "
There are several ways to find TDC - do a search and you will see. An easy way is as described by Joseph Donnelly:
"Find the approximate TDC where the valves for #1 are not moving. The #6 valves will be moving. using the alternator is not real good because the gear lash is taken up the wrong direction. Use the barring tool and rotate the engine in the direction it runs. this will be counterclockwise on the barring tool handle and clockwise on the harmonic balancer. #6 exhaust will be almost closed, and #6 intake just opening.
Put a piece of masking tape on the balancer underneath the truck, and affix a pointer made of wire under an oil pan bolt, running to the tape.
Go back on top. Remove #1 valve cover and use the KD spring compressor to compress #1 exhaust valve spring. Now the valve will rest on the piston, about 0. 090" down the hole. Put on a magnetic base dial indicator to the top of the spring compressor handle/stalk. As you rotate the engine, you will see a reading where the valve is up at its highest position, corresponding to TDC. Lets say that is 50 on the indicator. Rotate the engine backwards to say 30, and then start rotating forward to say 35.
Go under the truck and make a sharp line where the pointer is on the tape.
Go back on top and rotate the engine forward past 50 until the reading drops back to 35.
Go under the truck and make a second mark (sharp line) where the wire pointer is on the tape. Using vernier calipers, measure the distance between the sharp lines you made. Exactly the center between these marks is TDC when rotating the engine in forward direction (clockwise on the balancer looking at the front of the engine).
If you do a very careful job, this is as good or better than using the timing pin. "
After finding TDC I also made a mark by the crank sensor - that way I could see it from the top.
If you do a search you will notice that various people recommend different torque specs for the pump gear nut - from ma Mopar's original 122 ft lb - that was bumped to 144 ft lbs. Then we have Joe G and others stating you should go to 165 ft lbs. What is the best?.
The gear and shaft must be clean! Joseph Donnelly recommends the following for installing the pump gear:
"Use Mopar 4897150AB brake cleaner to clean the taper on the pump shaft and in the gear. Most parts house cleaners have heavy hydrocarbons that don't evaporate well and leave residues. Behind the gear is the approx. 4. 25" diameter by 15/16" deep hole in the gear housing for the pump nose (front bearing retainer). However, there is a “trough” remaining at the bottom because the pump nose doesn't end up flush (it's only about 7/16" thick). The trough therefore ends up about 1/2" deep. It accumulates engine oil, and will also accumulate the spray cleaner. The force of the sprayed cleaner then kicks up this oil and solvent back onto the taper you are trying to clean. Additionally, the bearing at the front of the pump shaft, right behind the taper, is a non-sealed bearing. It drains oil back to the crankcase, and also can contaminate the taper. When you spray excessively or blow dry real hard, you may be kicking up some of the oil from this bearing. In summary, use light spraying pressure with the cleaner solvent, and a light air pressure to blow dry the taper surfaces. I use the cleaner a couple times, with the last time being just before pushing the gear onto the tapered shaft. I also thread a long bolt into the gear so I can wiggle it and be sure all parts of the taper get cleaned. I blow dry carefully, again, not with real high flow/pressure.
Push the gear into place. Don't rely on the nut to pull it onto the taper. Leave the oil on the nut and washer because you have washed all the oil off the threads on the pump shaft. You need just the film of oil on the washer and nut to lubricate the threads.
DON'T use over 150 ft lb on the pump shaft nut. The threads were torn off on the $800 215 hp shaft by someone I know who used a torque of 175 ft lb. Then you have $500 to R&R the shaft. If the taper is clean and dry, you'd be surprised how few ft lb are really needed. If not clean and dry, you can't get it tight enough to hold. If there is a bur on the shaft, it won’t hold. "
If you do a search on "timing" or "pump timing" you will find most of what is contained in this post.
Good Luck!
Dan
Something that I've never seen posted in relation to timing a 12 valve engine is the information that the pump shaft nut wrench size is 30mm.
It's also a good time to adjust your valves once your through adjusting the timing. Just remove the other valve covers and run through the firing order (1-5-3-6-2-4). Get each set of valves to valve overlap by watching it's paired cylinder. #1 is paired to #6, #5 to #2, and #3 to #4. Intake valves should be set to . 010 and exhaust valves to . 020 clearances.
To make it easy to remove the #1 delivery valve holder on the pump, slacken off the inj. line clamps and remove the bolt from cylinder head that holds the clamp. Once the #1 injector line has been released, slip the nozzle nut as far as you can up the line and under the horn, then lift (enough to clear the nozzle) and slowly push the line toward engine. Now slip a piece of wood between the #1 inj. line and the others to keep it clear.
CAUTION: we're only using the line's springiness, not trying to permanently bend it, so take great care. Bent lines can result in restriction at the least and failure at the worst.
