When I look at a chart of timing data for a particular CPL or group of CPLs the left hand column lists degrees BTDC, the right column lists plunger lift. There are about 6 data points in each column. The data plate on the engine states the timing as well. Am I understanding this correctly that these charts are simply tools to let you know where you are BTDC by looking at your plunger lift?
Is the difference in timing between the various CPLs due to injector cam profile, injector pop off pressures, delivery valve size, emission requirements, or all the above? In the timing suggestions I have seen for enhanced performance I have not seen anyone recommend different timing points for a particular type of pump (160, 180, 215). Is this true or did I just miss something? Does anyone have a timing chart for a CPL 2174 they can email me?
Thanks,
Danny
Thanks,
Danny
