Sorry, no luck here. Cummins may have some kind of conversion in their engineering section, but since I have never had the time to play on the test stand to check rotation degrees vs lift, I'm a bit out of the loop on this one.
Perhaps when I get my pump on the test stand, I can make some sort of crude testing, but that's going to be some time in the future.
Just for the record, VE pumps on Cummins B engines are timed anywhere from 2. 1 to 1. 2. Many naturally aspirated engines are up closer to 2. The noise with the stock injectors at that point is very harsh, but the bigger injectors seem to dull it a bit.
