Pump wire guage?
GREAT experience with J&H Performance
How Much Did Your EGT's Drop, Removing OEM Muffler?
I just received a used DDUFM, but it didn't come with the wire tap for the pump wire. Anyone know right off what gauge the wire is so that I may pick one up tomorrow and really make some decent smoke... .....
You didn't say what the draw (amps) was, but i can't imagine it would draw more then 30a, 10 guage would do for that. write back if you know more.
I guess I wasn't clear enough. The injection pump wire to tap the fueling box into. The wire that necessitates the scotch lock connector.
My Edge Comp (same thing as the DD UFM, just slightly different programming) uses I would say a 16 - 18 gauge wire, it is fairly small. 10 gauge would be waaaaay to large. That's the size I use to run to my off-road lights :D and I use 14 gauge for the 30A relays, and the VP44 wire for the Comp is smaller than the 14 gauge. And I mean the actual wire size, not just the outside diameter, which of course would include the wire and insulation.
Tom
