Engine/Transmission (1998.5 - 2002) pumps, lines & whatnot
Engine/Transmission (1998.5 - 2002) injectors and pump
Thanks for the feedback...
I should have asked while I had the Cummins tech on the phone, but didn't.
What is the micron size for the stock fuel filter...
What is the internal bypass/relief and gph of the stock lift pump (psi and gph)?
Seems to me the internal bypass is set higher than the Carters you can order out of Summit.
Did a search, and couldn't seem to find the specs on the stock lift pump.
Thanks.
