I just finished installing my new FRRP100 Raptor lift pump. Luckily I saved the old seat foam when I upgraded to the new Geno's driver seat foam. It is a perfect cushion to lay over the front of the engine while working on the fuel system or injectors.
My fuel pressure at idle is exactly 15psi and cruise is 14psi. I was able to pull it down to 8psi on a pretty
steep hill.
I also installed a Vulcan big line kit (1/2" ID) from my factory filter to the VP44 for extra cooling for the VP44.
I installed a fuel pressure test port in the line from the filter to the VP44 and have a low fuel pressure warning
at the VP44 inlet fitting. I am waiting on a 1/8" schrader valve to replace the test port now, I REALLY thought when I ordered the big line kit with the pressure access port it would include a schrader valve. NOT!
steep hill.
