Do you know that oil flows through a 1/16" of an inch restrictor orifice when going through a bypass filter? Did you know that Cummins Inc. did a test and recommended bypass filtration in order to slow down engine wear? Talk with anyone that has an oil pressure gauge installed and they will tell that a bypass filter DOES NOT effect your oil pressure, period.
I'm an administrator of a motor oil website with 16K+ members so I try and go above and beyond in my knowledge of oils, and filtration systems.
I'm not saying that the $200 filter is junk, but it doesn't filter down low enough in microns to say that the oil is always clean like you state above. IT IS NOT A BYPASS FILTER. If you really don't want to change your oil as often, and truly keep the oil clean a bypass filter is the only thing that will do that. A bypass filter WILL keep the oil analytically clean, which in turn means extended OCI's and keeps the environment cleaner.
I had an oil analysis done on one of my older trucks and at 7K miles on the sample under a 100x microscope (Butler Cat Labs) my oil was said to "look as clean or cleaner than new oil out of the bottle". That is what bypass filtration does..... it keeps the oil clean, therefore keeping the oil from exhausting its' add pack and keeping the TBN high, which extends your OCI's.
My advice would be to look at the cold hard facts and study up on oil, oil filters, and bypass filters in general. Go to
Bob is the Oil Guy and read through the forums.
If the only thing you're concerned with is buying a filter and not having to worry about buying another one again, then by all means jump on it. A well constructed oil filter can't be beat, period.
The Fleetguard Stratapore uses synthetic media, flows and filters great (for a full flow filter) and costs around $10. 50 per filter. Put a bypass filter downline from it, and you have a bullet proof system. The Amsoil bypass element can go up to 60K miles before replacing the element, and the Fleetguard should be able to go AT LEAST 10K miles before changing it is necessary.
With your standard full flow filter AND a bypass filter you get the best of both worlds... ... . good flow (full flow filter), and super fine filtration (bypass filter). Best of luck... .
