Purpose of monitoring fuel PSI?
How to remove aluminum radio surround??
Additional year end rebate
I was wondering just what the purpose is of monitoring the fuel pressure. Is this only a concerned when you have a modified engine? Is there any point in monitoring the fuel pressure with a stock engine?
Inquiring minds want to know...
Thanks in advance,
Bryan
most of what i read here about fuel pressure gauges has to deal with the lift pump starting to fail or if the filter or pre-screen is clogging up. it gives you a little warning so that you hopefully wont get stranded.
this may not be an issue at 10,000 miles but from 50k on up it could be of assistance.
jim
Originally posted by lil red cummins
most of what i read here about fuel pressure gauges has to deal with the lift pump starting to fail or if the filter or pre-screen is clogging up. jim
Jim,
I have not seen any reports of lift pumps failing or pre-screen clogging up on the 3rd gens. Am I missing something here?
Thanks Ken
I got it on mine, since I didn't need the trans temp with a 6pd, and figured it would let me know if I got a bad load of fuel or the filter needed changing before the miles said to.
kbarlow, between reading TDR and DTR I've seen a couple posts about lift pumps dying and requiring replacement. But certainly not to the magnitude of the 2nd Gens, at least not yet.
Vaughn
I agree with Vaughn... there have been a couple 3rd gen lift pump failures. But I think they were all on "non-stock" engines.
Have you seen the size of the stock lift pump. Can you say small?
Even stock, the pressures can be around 6-7 psi. at idle. Again, cheap insurance for something that can be expensive down the road.
