tmacc,hammer and myself installed a pusher pump kit today to feed my weak lift pump. we also installed rays bj bolts and drilled the schraders. BANG!! 15+psi at idle (10psi before). 10 psi at WOT with the powermax and ez in the on position. ( 0 psi before). this seems like the way to go. sure beats all the hassle involved in moving a pump from it's stock location to back by the tank. hardest part of the install was getting all that darn tape off the pump wire so that we could splice to it with a scotch lock. tmacc did a superoir job drilling the schraders and installing the bj bolts. we also discovered a perfect place to mount a fp sending unit(tmacc has pics)
thanks again guys!!!
