Finally got a Carter pusher pump installed this afternoon, no more lp troubles for me (hopefully). Thanks goes out to Gary - K7GLD, for all the advice. Anyway, its just a basic Carter 4600 pump in front of the tank on the frame rail, with an in-line fuel filter off of a Case IH 9310 tractor as well. Idle's now at 20 psi, and wont pull below 15 psi WOT, empty weight. So far so good, a vast improvement over the stock situation, if you havent added some form of booster yet, dont delay!
