Engine/Transmission (1998.5 - 2002) pusher pump parts list
2nd Gen Non-Engine/Transmission Keyless remote lock problem
Engine/Transmission (1998.5 - 2002) Air fillter change when?
This is what I just did.
I bought a Carter 4600HP (7psi, 71. 95 in Summit). I also bought 2 3/8npt to 3/8" barbed fittings (for the pump to fuel line connections). It also takes atleast 1' (2' is better, it's cheap) of rubber 3/8"I. D. fuel line (I used 6' to redo all of my banjo's as well). You also need 1 relay (minumum 10A), 1 scotchlock (to tap the existing pump control wire and feed the relay), approximately 15-20' of 14ga wire, several ring terminals (for ground, lift pump, and battery connections), several connectors for the bottom of the relay (4 to be exact), a small pipe cutter, two hose clamps (the pump comes with two and you need 4 total), and some wire ties. You might also make a cap for your fuel line if your tank has over about 1/4 tank otherwise gravity will coat you with diesel. I also used some split loom to cover all my added wiring and make it look factory. If you need directions on how to go about doing the whole process just ask.
Nathan
I got my kit from Fred Swanson @ Desert Diesel Parts for $135. Includes Carter 4600 7PSI pump, rubber fuel line, hose clamps, 30A relay, 14ga wire and all directions you need.
Sorry I can't remember his email or phone right now... His email *might* be -- email address removed --
Tom
