I'm looking at installing a carter 4600 pusher pump and after reading over all the posts I could find still have a few questions. I need 3/8 rubber fuel line right? How did you guys attach to the stock steel line so it didn't leak? Do I need different fittings then supplied with the 4600 to connect the rubber line to the pump? Where at is the best place to tap into the stock fuel lines/mount the pump? The feed line is on the bottom right?
What color is the wire which I need to tap into on the stock pump?
I hate to make another post about pusher pumps but I need to get this figured out soon so I can the supplies I need to install the pump.
Thanks,
Matt
Thanks,
Matt
