Pusher Pump Results.
lift pump
HELP What to look out for in a '95
EMD... . yep, I thought about a BG pump, but I only know of two that tried one, both the BG220 I believe, C. Sutton (correct me if I'm wrong, Chris) who's BG died after 2 months and another TDR member whose name escapes me right now. Don't know if his BG is still alive as I haven't seen a post from him in a long while. I think the problem with alot of the real big pumps is that they are designed for more of 'track use' then being used as a daily driver.
Scott W.
DOH!!!! Senior moment has passed, it was Chad sheets that had the other BG !!!! Chad, you out there ???????
Scott W.
