So I’m having issues with my oil pressure sending unit and from research I’ve heard that the stock one isn’t the most reliable. I’ve also heard that putting one at the top of the oil filter housing reads higher pressure than the stock position. Some other people in other post have talked about putting a t fitting in the stock position to run both a mechanical gauge and a stock one. What are y’all’s thought on doing this and how should I go about it? So I put the t right in the block and run the 2 gauges off of that. Or a saw one person said he ran a line away from the block and put a t. What size t do I need and is there a certain material to use, what size line, what material do I use for the line, ETC.
