2nd Gen Non-Engine/Transmission Putting side lights on my Motor Home
Engine/Transmission (1998.5 - 2002) Describe "The Drone"
Engine/Transmission (1994 - 1998) Camshaft Seal
I had a set of grab Handles that light up orange and putting the side lights on take a little time. I have not done the front yet but my wife says It looks like a Christmas tree now. :-{} I don't think she thinks much of all the lights. One thing for sure you will see me comming. The lights stand out In the dark.
Naw, you don't have nearly enough lights on that rig!!
You only have too many lights if your truck is mistaken for a chicken-hauler after dark. :-laf
I replaced ALL the regular Marker lights on the side with 14 LED lights that are the same size but will last a long time... .
Ge them here
http://www.ledtrailerlights.com/cm/cm_M23015.htm
Here is my 60 LED tail lights ... . I have 2 on each side. but the outter 2 is Running light and signal and brake while the inner 2 is onlu running and brake..... So all 4 are brake but only 2 are signal... .
I put these on the side in mid trailer. They are running light and turn signal... . The brake light operates as well
SO Much for the trailer... ... ... ... ...
Here is the 12 LED lights available at truck stops...
heres the same 12 LED lights on the side of the frame for the windeflector
And finally here is a 6 LED light for turn signal
