PW inj pump settings
Hi/low beam switch problem...
Hello all. I'm installing my PW injectors this weekend and was looking for advice from those who already have these injectors installed as to what inj pump changes you have made and the results they had. I'm not looking for max power, I'm more interested in pump changes that will complement the injectors and not hurt long term pump reliability. I also plan to have a shop adjust my inj pump timing; what SPECIFICALLY do I need to tell them to set it too for my setup. Thanks in advance for the help. .
93 D-250 club cab. Auto 3. 54 gears. 77k. 3. 5" exhaust, Westach gauges.
Fuel settings & afc adjustment are set to your preferance, how quick do you want the fuel coming in verse smoke level, that will very depending on turbo housing, exhaust system, gear ratio's.
Maximum fuel setting will depend on how far you want to push the pump & the egt envelope.
Timing should be set to 1. 4-1. 5 mm lift, from its current setting [if correct] of 1. 25 mm lift.
Piers, BD engine R&D
