PW injector performance increase
loose steering wheel
First Generation Aftermarket Air Conditioning?
The numbers are in!
The following 4th gear acceleration times are before/after the PW injectors and pump timing adjustment.
Both sets of numbers are the average of 3 runs at 150 feet above sea level 68-70F and about 50% RH-basically ideal conditions.
1000-2000 rpm: 7. 4/6. 5
1500-2500 rpm: 8. 0/6. 5
1000-2500 rpm: 11. 9/9. 5
20-50 mph : 11. 0/8. 7
Before I did anything to the truck, it would do the 20-50 mph run in a 12. 5 seconds.
The injector change/pump timing alone made more difference than all the mods up to that point-Banks stinger plus, max diaphragm fuel rate and turned up full load fuel.
An injector change is THE ticket.
'93 W350 Club Cab, 5 sp. , Factory Options: LE, 4. 10, LS, 7600 lb. rear springs, tachometer, front stabilizer bar. Mods: Banks stinger plus, Linex bedliner, 25,000 lb gooseneck, 10,000 lb receiver, Tekonsha brake controller,
PW injectors.
Hey Mark93!
As I mentioned before congratulations on your AWESOME results. I personally appreciate you taking the time & publishing such a in depth comparison on your modifications. Your writing definately has a very technical & readable format, I've enjoyed your information and frequent post!
Keep those post coming! Smoke on Brother!
Keeno
1992 W250 5spd. 3. 54 gears, LSD, JRE enhanced VE Injector Pump, BD High Output Injectors, Banks "Stinger Plus" consisting of a 14cm2 wastegated housing, 3 1/2" JRE modified exhaust/muffler, pyro/boost gages, K&N, Skyjacker 2 1/2" front suspension lift to clear 305/70R/16 Goodyear MT's, Mag-Hytec, Amsoil
It's sure nice to know where the money is best spent. You can easily be conned into the $1500 exhaust system without much in the power department.
Thanks Mark93 for all the info. I'm looking at getting a 92 CC 4X4 for hauling the pets/kids and trailer. Now I have a much better idea of what BOMBing route to take.
Jason's Lil' Mack - 89 D250LE 2WD 5Spd 3. 55 Reg Cab. K&N,"tweaked pump", 3. 5" Exst straight,E&M Custom seats. Bosch H4, PIAA 80W/80W HdLites. Bosch 100W Driving. Bosch 55W Fogs.
218,000 miles (355,000 Kms)
7450 Hrs.
