The opening pressure is very close to original... they should have the same number of holes, the holes are larger, and if I recall correctly, the needle in the nozzle lifts farther.
There should be 5 holes, if memory serves, in both the stock and the PW injectors. And, to second the previous comments... if you run at purely stock pump settings, it will not smoke more than a mild haze ,and most of that can be cleared up with a 12 or 14 CM wastegated housing. Set your maximum boost to around 24 or so.
You will find that power will be increased, and egt's lowered a bit if you advance the timing from 1. 2-1. 25 to 1. 3-1. 5. They seem to run darn good at 1. 4
BD sells some injectors that must have cavernous holes in them, because tey REALLY give you an increase, but from what I can tell, they smoke... . and I hate smoke. I'm just enough of a perfectionist to be determine to outpull the PSD's with no smoke, and getting better milage, too.
