All you have to do to check the accumulator is to start up the truck and let it idle for a minute in your driveway. Now, shut off the engine - don't move the steering wheel. After the engine is shut down for 5-10 seconds, press the brake pedal. You should still have boost assist from the hydroboost accumulator for 1-2 applications of the brake pedal if the accumulator hasn't lost its charge. If you don't have any boost on the first brake pedal application after the engine is shut down, the accumulator is bad.
Rusty
