I finally decided to buy some guages, and put them in a couple of weeks ago. I've been monitoring my readings and just want to compare with some of you guys for a sanity check before i put in a plate and GSK. At idle my pyro reads 300 Dg & the boost is at 0. Max temp reached so far was 900 DG at 75mph on the Cajon pass grade. boost is 10 psi at 200 rpm on flatland. Max boost recorded was 20 psi climbing. As you can see I'm semi stock. I plan to order plate and springs this week. Oo.
