I have been thinking about this "turbo cool down" issue since I got my CTD 9 months ago. I have read about a million posts that debate pre-turbo versus post-turbo pyrometer installation. I understand how EGT can indicate problems and keep one from melting a motor. The part I have an issue with is using this parameter for turbo cooling.
I realize we do not want to just shut down our engines after long and hard use. Ultimately we want to ensure the oil is not baked onto any critical rotating parts. I can see how monitoring EGT will indicate a drop in turbo temp, but if we're worried about baking the oil, why are we not monitoring the temperature of the oil exiting the turbo?
If we can measure the temperature of the oil in the pan, and can measure the temperature of the oil exiting the turbo, we can indicate a differential between the two. With some research and trial and error, we could come up with a differential temperature that we could consider normal. After working the engine hard, monitor this differential until it drops to a "normal" level and then shut it down.
Now, I'm not an electrical or instrumentation engineer, but I would think setting up two sensors in some sort of circuit to indicate a differential should not be that difficult. I'm not advocating ignoring EGT but would the oil temperature differential be considered a reasonable way to monitor turbo temp? Am I out to lunch? I appreciate the wisdom of those that have a more intimate knowledge of this engine than I.
