I seem to remember a formula/rule of thumb that said +10*F for every 1 lb of boost if your post turbo. That is, in the radius of the elbow.
So, 20 lbs. of boost is roughly another 200*F above gauge reading. Also, try to let it cool down below 300*F when shutting down. I always let the temp drop to about 250* before turn-off.
Max post turbo temp should not exceed 950*F because to get there your no doubt running WOT with max boost, or very near it. I read here that 1250* is the start of softening point for critical component metals.
Personally I've never exceeded 800* at 18 lbs boost for more than a couple minutes before gearing down and cooling out a bit.
Just my personal preference though.
Regarsd, Bush'
