Pliska,
My amplifer box on my old gages was installed inside the truck. I could't get wet but it would have a real high pitch/whine and after it warmed up it would stop. Then it would just show 600 degrees at idle and 12 just going down the road.
As far as the EV2, I put the new K probe in the same hole as the other and ran my harness into the inside of the cab. Hooked up the wires as the instructions said and daisy chained the power to the gages. The backlighting works as it is suppose to. When turning on the ignition, the gages zero down to the stop, then rise slightly. I then remove wires from the connector, cut them off and slit the insulation(it is getting cold here and the insulation is hard)of the wires, heated them with a hair dryer and installed them. Then took the probe connector off from the harness in the engine compartment and ohmed the harness from the probe connection to the gage connection, works as advertised. Hooked everything up, installed the gage and started the engine and took it for a drive, nothing on the EGT gage. So, Geno's sent me another gage. Will hook up the new gage Monday to see if it works. If not will slave in the entire new set up and see if it works.
WD
