Weird thing happened lastnight. As I was slowing down to pull in the house I look over and the Pyro is jumping all over the place. So, I am like, GREAT!!! and I continue to pull into the driveway. Well, due to the LOUD mudtires on the ole` dodge, I had the raido up pretty loud, and I turned it down, and the pyro comes back to where it should be and is steady. I then turn the radio back up, and again pryo jumps around. This morning on the way to work, I notice that everythign is normal, even when I turn the radio up high.
Note:
- I do have a factory tweeter in the A-pillar
- When I installed the A-pillar I just glued it to the factory a-pillar, and I cut a big hole in the factory pillar.
-Upon installation I was careful and I soldered all connections and used Shrink Tube on all exposed wires.
Before I tear into it, what do you guys think, do you think it may have been a pyro wire laying close to a speaker wire, and its not a big deal, do you think that its a wire rubbing in two? The gauges have been installed for about 2 years, and have had NO problems with them in the 2 years.
Thanks in advance for all your help!!!!
Note:
