It's pretty easily fixed. A boost elbow and boost fooler will take care of it, if you don't want to install a "box".
When I installed my Edge EZ (with its supplied boost elbow) along with a 4" exhaust system the same weekend, maximum pre-turbo EGT dropped from 1300 degF @ 21 PSIG boost to 1100 degF @ 30 PSIG boost. The great majority of this drop in EGT came from the increased boost. The EZ has a built-in boost fooler.
If I had it to do over and were looking for a good towing "box", I'd go with the Diesel Dynamics True Torque Power Module (TTPM) instead of the EZ. The TTPM is an EZ with DD-specific programming that doesn't have as much timing advance as the EZ - this helps when towing with the higher compression ratio of the HO. IMHO, the EZ is a little too aggressive on timing for the HO when towing, especially with bigger injectors.
Rusty
