First time I've seen torque figures from the Marine Engine - this is a "New" venture with mercruiser..... http://www.cmdmarine.com/pdfs/4081898_0903.pdf
Originally posted by RustyJC
Like most marine engines, the key to these ratings is the sea water heat exchanger cooling systems. Having an infinite supply of 60-70 degF cooling medium for the intercooler, oil cooler, engine coolant heat exchanger, etc. pretty well takes care of any air density and overheating problems.
Rusty
Originally posted by hammersley
Pushing a boat than pulling a trailer (or our fat butts). Those marine engines are always running "up-hill" in that they are always working hard against the water - no coasting or downhill runs - or stopping.
Originally posted by Rosco
If someone can show me a Powerstroke or Duramax making that kind of power in a marine setting for thousands of hours on end and I will eat my Cummins piece by piece.
Originally posted by A Johnson
"Rating is limited to 1 hour of full power out of every 8 hrs of operation. "
Did you notice the 19. 9 gallons per hour fuel consumption.
A Johnson
Originally posted by nickleinonen
and a locomotive going 75mph down the track with 15,000' of train behind it will use 200+ GPH
when making/using power, you use lots of fuel
