My friend called Quadzilla and was told that 1 is stock, 2 is timing, 3 is timing w/fuel at 95 horses and every number after 3 is 12 horse power more. The 2000 tunes pull harder in the begining.
For some reason, I thought `0`was stock, `1` was `max mileage`, then the power comes on progressively from there... but I`ve been looking at so many tuners that I have no idea about the details. I have my Adr/pulse on the way so I'll see when I install it.
HHMMM knowing the above what is zero? I was thinking 0 was stock but what do I know, absolutely nothing!!! SOOOO if I was to have a mechanic work on this or god forbid a dealer I should program it level 1 as quad say but back to stock before. Exactly what would you guys do b4 taking to somebody to work on like quad says put back to stock. Does that also mean remove all hard attachments and program to what exactly before doing that?![]()
If you are going to use your warranty, I would definitely remove the unit from the truck. If you are over 100k, I would just turn it to level 0 and take it in. I have only had my truck back to the dealer once since I bought it for the VP44 that went out 25,000 miles ago. Truck was fairly stock back then. I am at over 95k miles now, hardly any warranty left.
