Quadzilla Adrenaline help?
Oil leak from where?
Pvc
Hey guys, i finally got the compounds on and working correctly. My problem is i can only run the adrenaline on setting 6 out of 10 or i get a fuel error code. I believe what is happening is the programmer is over pressuring the rail. The programmer does allow me to create my own tune but i have no clue on what to adjust. It doesn't say timing adj, or pressure adj but has all kinds of other settings. Someone please help this neanderthal figure this thing out!
Forgot to add that anything past setting 8 (i believe 100-120hp) and my egt's hit 1450 as soon as i hit overdrive. What i would like to figure out is how to adjust the timing to about 7. 5 degrees or so and add pulse width while decreasing rail pressure.
Anyone running this programmer? I sent an email to quadzilla a few days ago but have not had any response there either. I have been running it on the lowest setting for fear of adding too much timing or rail pressure.
I spoke to Jeremy over at Quadzilla. He has been working with me over the past few days trying to figure out why i am getting a fueling error code. He also was nice enough to explain to me what each custom setting parameter does and how to set it. I havent been able to drive the truck for a few days due to an injury during training, so ill post the results as soon as i can. If anyone is considering Quadzilla i certainly say go for it!
Play with the rail setting, as it will ramp up REAL quick. I believe I set the same code a couple times when I tried out the Adrenaline. Just be careful playing with the custom tuning; I did and melted an engine stacking it.
Listen to Jeremy, pick his brain, and be careful. Box runs good
