Quadzilla Adrenaline installed
The dangers of winter fronts?
Tractor Supply Co. bulk 15w-40 CI-4
Well I got the Quadzilla Adrenalin without the monitor.
I installed everything and I also had to rerplace my old map sensor and IAT Sensor. Then Installed the box.
Everything went good and installed the oil temp and Tapped the EGT probe in the manifold. . Have to tap one of the wires on the VP44 and hook to the Data plug and map sensor. . Power wire to battery and a sensor wire to Switched power. . Pod is mounted on top of my column mounted to the high Idle box. . right where I can see it.
So try to start it. . no start. . Long story short, found I had a small problem with a fuel vent problem where it does not start. . I had filled it up and it just plugged. . I unhooked the box, and got the engine started on a fluke,. . took a 65 mile ride to burn off some fuel, came back, shut it down,. . start up. . no problem 3 times... hjooked the box back up to the sensors, hook the batteries up, starts up. . 3 times in a row so I guess my fuel/vent was the problem. .
Anyway. . too late at night now to test out the box so stay tuned. . I will take a few pics and post them. and see what the box will do. . I set it on #5 which is 105hp gain. . we will see how it feels. . I know how it feels now. . Like a fORD!!! lol... .
So thats what I did today... also fixed my stepsons car, 2 belts and a Crank sensor that got some of the whitewash off my hands... lol... So tired tonight.
