Anyone tried mounting the Commander above the rear view mirror? Would the wires be long enough to reach where they need to go. . ie the turbo? I see they now have pods for analog gauges for that location.
I've got the A-Pillar for mine. Pretty much a few wires to tap and drill/tap for pyro. The FP is an easy install. You remove one banjo bolt from the top of your CP3 and install the adapter and sender. Make sure when you do the FP sender that you have the fiber washer, then the wire, then the nut in that order on the post.
Wheres the cheapest place to get this with a A pillar mount and the fuel pressure monitor kit.
Extreme diesel (343. 00) had it a little cheaper than Geno's with free shipping included. Any others?
thanks
BillD
