i had just bought a new quadzilla commander and am having problems. i got it all installed and every thing was working except for the boost. so i cut the MAP wire and soldered the commander boost wire to the MAP wire. i tripped a few codes in the install but ijust cleared them with my smarty. now every time i turn on the truck the RPM screen is blinking and i have to go to the warnings menu and turn off all the warnings that just keep setting themselves. then once i get all them off and get into the 4 parameter display mode then the whole screen flashes and the EGT's read like 1900 degrees, 0 psi boost, 29630 rail psi, and 43 for the fuel psi. i dont even have the fuel psi kit installed. and nothing changes. it just stays at those numbers and flashes. i just bought it but it says it was built in 6/06. then everytime i turn off my truck i have to go through all this again. whats going on with this thing. i know for a fact that it is installed correctly. your help is greatly appreciated!!!
