bgilbert said:
:Yawn:. .
4BT man, the spec is 5-7psi after filter for a healthy lift pump. Minimum 3psi under load. Sounds more like the fuel pin that rides on the eccentric cone or pin is sticking on you at times. Thus giving low power or not as much power as in the past. Seems like you discussed this before. Greenleaf can fill ya in on troubleshooting a sticky pin.
hey ***... I wouldn't be so quick to diagnose the problem because I am not able to get the power off idle that I used to have before, even with stock injectors. Therefore I highly doubt it is a stuck pin issue. I will read through and see if there are directions on seeing what I can do about an unstuck pin but it is well lubed and appears to be working well... I have also not replaced my current AFC boost controller hose with something more rigid, yet...
The only reason I think it might be my lift pump is because this is the only real thing that has changed from then until now. I used to use an electric lift pump with a small inline racor under pressure. I now use the mechanical lift pump with a big-*** racor under vaccuum... The problem with the electric lift pump was it cycled fuel through the pump too quickly and would cut out around corners, etc, when less than a 1/2 tank of fuel...
There was a time when, even with my dinky little stock H1C, the engine was so loud and powerful off idle that it sounded like the loudest most cranked up 24 valve you have heard and the truck was a rocketship, I recall getting pulled over going up a one of the 20 mile grades at 83 mph with a lot more power and room to go and the engine was a just torque monster... Today I can't even keep it in 5th, even with tons of fuel dumping it seems. The power was throughout the whole curve, with very little smoke at the time, including even at idle... The only reason I turned it down was for noise and because the mileage was poorer... Since then, I have not been able to mimic this power with the same settings. I have reasonable EGTs and decent power but am smoking like crazy, especially when cold... I also occationally use this truck for some of the biodiesel coop's events as a promotional truck for "clean renewable biodiesel" so in theory it is important that it isn't smoking like crazy, which it is now...
GL, I did reset the pump timing slightly advanced but did not use any tools. I advanced mostly because of what is said here but assumed because it didn't slip a tooth or anything that I wouldn't need to reset back to normal before advancing. I am probably about 1/4 in clockwise advanced as the pump sits, but not all the way...
Also this problem has been for a long time and before the pump rattled loose so I don't think its timing related either... It started when I started using ether to get the truck to start on really cold mornings (less than 15*F). I started gradually losing power and getting higher EGTs and slight loss of coolant (though its possible I was leaking some as well) and determined I had a blown head gasket (for months actually). So I replaced it and the truck is actually doing very well now but there appears to be some sort of power loss isssue somewhere that I can't/havn't been able diagnose yet...
So that is basically what is going on so far...
