thinking about installing a lock up switch in my 99 3500 4x4 that is curently running a dtt trans, convertor(90%),and valve body. question is i only have the billet input shaft not the out put shaft am i in danger of breaking the output shaft if i lock the convertor after it makes the 1st to 2nd gear shift then let it shift the rest of the gears with the convertor locked.
thanks for any info
thanks for any info
